Warranty ???'s
1. Will they cover the wiring harness under the valve covers. (motor missing)
2. will they cover the turbo pedastal leaking oil down the back of the motor to the drive.
3. water pump leaking water.
4. Injectors. (motor missing)
My truck is an 02 with 76,000 miles on it. Does the 100,000 mile warranty cover these items. I hope at least the turbo leak and the wiring harness.
New oil & filter, new fuel filter, new air filter and still missing. Harness, injectors, and TPS, are my possible causes at this point.
I just had most of the things you described done to my truck under warranty so I am sure you could.
7.3L PowerStroke Diesel Engine Coverage
The New Vehicle Limited Warranty covers certain direct injection diesel engine components against defects in factory-supplied materials or workmanship for five years after the warranty start date or 100,000 miles, whichever occurs first.
After the end of the Bumper to Bumper Coverage period (three years or 36,000 miles, whichever occurs first), you must pay a $100 deductible for each repair visit.
Ford Motor Company or Ford Motor Vehicle Assurance Company covers these components: cylinder block, heads and all internal parts, intake and exhaust manifolds, flywheel, timing gear, harmonic balancer, valve covers, oil pan and pump, water pump, fuel system (excluding fuel lines and fuel tank), high pressure lines, gaskets and seals, glow plugs, turbocharger, powertrain control module, electronic driver unit, injectors, injection pressure sensor, high pressure oil regulator, exhaust back pressure regulator and sensor, camshaft position sensor, accelerator switch.
NOTE: Some components may also be covered by the Emissions Warranties, with no deductible.
