power point quit
Old Dec 2, 2004 | 01:29 AM
honeyb's Avatar
honeyb
power point quit
checked the fuse under hood it is fine, are there anymore that i missed? did not see anymore in manual
how hard is it to get that out of dash and how can i access it, through radio? glovebox?
thank you,
courtney
Old Dec 2, 2004 | 04:50 AM
blackf3504dr's Avatar
blackf3504dr
Did you also check the fuse panal in the dash ? Is this is the power point in the dash ?If so the wire could have been knocked off .
Old Dec 3, 2004 | 01:13 AM
honeyb's Avatar
honeyb
this is the power point in the dash, i did not see anything in the manual that shows a fuse for the power point under the dash, just under the hood, did i miss it?
when you say the wire could have been knocked off do you mean the plug to the back of the power point? do you how i can access it? thru the glovebox maybe?
thank you!
courtney
Old Dec 3, 2004 | 01:39 AM
johnsdiesel's Avatar
johnsdiesel
The power point has a fuse in the cab. Check there first to make sure the fuse isn't bad.
Old Dec 3, 2004 | 05:26 PM
mybigredford's Avatar
mybigredford
my powerpoint wouldnt work either, and it turned out to be the fuse, and yes the fuse is in the cab
Old Dec 4, 2004 | 10:00 PM
honeyb's Avatar
honeyb
ok thanks guys, going to check the manual again now, i swear i did not see a fuse in the cab for the powerpoint, is it with anything else or called something different?
thanks for your time
courtney
Old Dec 4, 2004 | 10:50 PM
honeyb's Avatar
honeyb
Unhappy power point help?
i do not see a fuse listed in the manual for passenger compartment power point,my truck is an 01.???????? i checked them all and they look fine? can you tell me what number you replaced? i am going to replace the one under the hood anyway just in case something is wrong with it and i don't see it? does anybody know how to get the thing out of the dash?
thanks again for your time
courtney
Old Dec 5, 2004 | 08:33 AM
f350xlt460's Avatar
f350xlt460
i thought it was labled "cigar lighter/obd conection" or something like that.
Old Dec 5, 2004 | 10:20 AM
honeyb's Avatar
honeyb
in my truck the power point and cigar lighter have different fuses but i checked it anyway and cigar lighter is fine
timboy
Ford Truck Parts for Sale
Oct 5, 2014 09:45 PM
61 uni
Sep 24, 2012 10:11 PM
crystalshane
30
Feb 14, 2010 10:39 AM
meditlondon
3.8 & 4.2L V6
Apr 29, 2007 03:18 PM
