Sponsored by: Auxito
Transfer Case Question
Old Dec 1, 2004 | 11:18 PM
onedangerouswookie's Avatar
onedangerouswookie
I have a 1997 F150 4X4 4.6/V8 with an Auto Transmission. My original problem was my speedometer quit working. I took my speed sensor out and found it was the gear on the end of the sensor. I replaced the speed sensor gear and within 75 miles of driving all the teeth were flatened again. What all is involved in the transfer case (gears ect...). I have never been into a tranfer case before. I need some advice whether or not I should take it to a shop or do it myself. Thanks.
Old Dec 3, 2004 | 08:35 AM
Racerguy's Avatar
Racerguy
The speedo drive gear on the output shaft is replaceable. You remove the extension housing (5 or 6 torx head bolts) then there is a springy spacer in front of the gear that snaps off. Push the gear forward and remove the ball that holds it on the shaft. Dont lose the ball. Then the gear slides off the shaft.
