Axle swap info
Old Dec 1, 2004 | 10:46 PM
EBronco's Avatar
EBronco
Axle swap info
has anyone put a 1 ton sterling axle under a 75 F250 4x2 crewcab or similar truck ,is the width ok and how far appart are the spring pirches?
Old Dec 3, 2004 | 11:37 PM
cnelson's Avatar
cnelson
There is a 78 f250 crewcab on ebay that was converted from 2wd to 4wd using a dana 70 front and a dana 80 from a later model truck. The ad says the rear is from a 99 f350. Don't know what the front is from. It does look like the tires stick out a little more than usual. So they might be a little wider.
Old Dec 3, 2004 | 11:39 PM
whd507's Avatar
whd507
I have seen the 80-later axle in 79-earlier trucks, but I cant speak to how easy or well it works. I know its been done though.
Old Dec 12, 2004 | 10:27 AM
Scot's Avatar
Scot
I am running a mid 80's F250/350 D70. It bolted in except for brake cables. The frame width has not changed since, to my knowledge.
