temperature sending unit?
Old Dec 1, 2004 | 08:05 PM
nick150's Avatar
nick150
i have been having a fluctuation problem with my cooling sys. temp. just for laughs i replaced the new sending unit with the old one tonight to se if it would make a difference in how much it fluctuated on the gauge.
the old unit reads 194 ohms and the new one read 108 ohms. this si with engine cold and about 45* outside. the new unit would put the gauge on the "M" of normal and it would fluctuate from the "N" to the "L". the old onekeeps the gauge right on "N" but it still moves a little bit. is there any other test i can perform to these units to see wich one is correct?
thanks guys.
Old Dec 1, 2004 | 11:28 PM
Pikachu's Avatar
Pikachu
Check them when you know for certain they are the same temperature. Since the guage isn't marked in degrees, the reading is relative anyhow. Get to know where it should be at normal operating temperature.
Old Dec 2, 2004 | 10:06 AM
nick150's Avatar
nick150
the engine was at the same temp when i checked them. that is my cause for concern. the old one read 194 ohms and the new read 108 at the same engine temp. i am trying to figure out what the resistance should be at a certian temp or if there is any other way to check these units.
thanks for all of the help.
MFplowboy
Feb 13, 2017 06:35 AM
ford5.8
Oct 19, 2016 06:18 PM
JonnyAce
15
Jun 16, 2015 08:34 AM
rswhitmore
Mar 20, 2015 10:27 AM
btacarlton
Oct 4, 2005 01:54 PM
