flywheel question
Old Dec 1, 2004 | 05:57 PM
ozarkboy's Avatar
ozarkboy
flywheel question
I just got through putting a replacement 302 in my jeep but am having vibration problems and am confused on some information. To start with the 302 I removed is a mid 70s engine, the one I replaced it with is an 83 model. I started by using the harmonic balancer for the newer engine but switched it after noticing the vibration. But still had the vibration. The flywheel and clutch was bought for an 80 model ford truck, since that was where I got the transmission. the question is, does the flywheel and harmonic balancer counterbalance(whether 28 oz or 50 oz) each other or do they counterbalance the crank?
Old Dec 1, 2004 | 08:05 PM
stevef100s's Avatar
stevef100s
You need to use the balancer and flywheel for a late 81 or newer. Both have to be replaced as a pair, for the 50 oz counterbalanced engine.
Old Dec 2, 2004 | 06:21 AM
ozarkboy's Avatar
ozarkboy
Hey thanks, I kind of figurerd as much since, just wanted to make sure.
Tommyrog
19
Nov 30, 2019 02:45 PM
bsraborn
Apr 19, 2016 07:47 PM
eBronc3
1966 - 1977 Early Broncos
Nov 5, 2015 05:38 PM
FordF100man
Oct 15, 2015 11:29 PM
1ole4d
Jan 7, 2009 10:30 PM
