various Injectors
Old Dec 1, 2004 | 02:45 PM
Wellcraft's Avatar
Wellcraft
various Injectors
Whats the difference between turbo injector and an ordinary one..??
On my engine original is not turbo coded but the new ones i installed is turbo coded..
Old Dec 1, 2004 | 08:32 PM
PLC7.3's Avatar
PLC7.3
There are three different injectors used in 6.9 & 7.3L engines - one for the 1984-1992 6.9's & 7.3's, one for the 1992 1/2 - 1994 engines that Navisatar referred to as the "P&E" (performance & emissions) engines and one for the 1994 turbocharged engines. The three were D-E-G injector codes in that order.
In reviewing the drawings I see that in addition to to different nozzle opening pressure for the injectors, there are a number of differences between the nozzles including:
different pintle diameters, pintle bore clearance, valve overlap length,valve extension etc. all which result in different valve lift vs flow characteristics and therefore result in the different injectors for the different engine applications."
All the operating pressure ranges are different, the pressures match with the respective IPs which are all different. The 92.5 and beyond attain the power at less rpm.
Old Dec 1, 2004 | 09:31 PM
banks7.3's Avatar
banks7.3
I have a 91 F-350 with a 93 7.3 non-turbo motor. I installed a Banks sidewinder turned IP up 1/4 turn. Which injectors would be best for my application?
Old Dec 1, 2004 | 10:32 PM
PLC7.3's Avatar
PLC7.3
The code on the injector flats should be E code if the engine tag states 92.5 on the timing gear cover by oil filler. That should have a 5013 pump, #s found on the info plate.
