Differential's used
Old Dec 5, 2004 | 02:03 PM
classyfish's Avatar
classyfish
Maybe depends on what part of country.. My bud John, has 2 Dana 60's, both are the 3.54. There ya have it..
Old Dec 5, 2004 | 02:53 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
the 60's in my 78 snow fighter are 3:54's, definitly snag that truck, the axels are worth a pretty penny if they arent tore up.as far as the cab goes, it can be replaced.
1976 F-150 460 780cfm 4bbl holley- Hot Röd
1978 F-250 Snow Fighter 1 ton 4X4 35 inch tires
351m 500cfm 2bbl holley- Big Daddy
1978 Ford B-700 Bus 389 4bbl holley 10 speed
Old Dec 5, 2004 | 03:41 PM
Brian794x4's Avatar
Brian794x4
you bet, Im going to get ahold of the guy here soon, and try to make it sound like i just want parts and pieces of it, and it should be cheep to be had anyone know if it had a devorced transfercase or the type my f150 has....i dont even really know how to tell if i had the truck here to look at. Thanks boys
Brian
Old Dec 5, 2004 | 08:25 PM
Mark VIII's Avatar
Mark VIII
Hello I also have a 78 F250 with dana 60 front and rear 410 gears. Mine has the married T-case I believe the married case started around 77.
Old Dec 5, 2004 | 09:46 PM
SwOkcOffRoader
a divorced Tcase has a driveshaft between it and the tranny, so you would see 3 driveshafts on a divorced Tcase and only 2 on a married Tcase.....
Old Dec 6, 2004 | 04:17 AM
Brian794x4's Avatar
Brian794x4
ahhhh, thanks for that little tidbit, i was kinda thinking that might be how it happens, but now i know. im rather excited about it....other then the fact that i gotta buy different wheels again. But man...tough diffs, and if im lucky, a bit better gear ratio will make it ten times worth it
Brian
Old Dec 6, 2004 | 08:14 AM
highboy1975's Avatar
highboy1975
i don't remember seeing you say what year CC it was. this makes a bit of a difference on which d60 your going to be getting. the 78/79 high pinion d60 is the best, but the early ones are a low pinion and aren't as strong. either way, it's a rare truck and you should snag it up.
Old Dec 6, 2004 | 01:27 PM
Brian794x4's Avatar
Brian794x4
highboy1975....you ARE right, i never specified what year, as im not 100% sure. I know its the older grill style (73-77) but thats all i know as of now. I hope its not a low pinion...but i guess thats what'll it will turn out to be. Im going to drive up there again today, and tromp through the snow to have another look at it. I know its a 60 for sure, its a huge pumpkin, has 4 bolds holding the king pin grease plate on with a nipple on the top, and it has the biggest ugliest hubs from hell, and i coulda swore i saw drum brakes...
Brian
Old Dec 6, 2004 | 02:47 PM
leadmic's Avatar
leadmic
If it has a 400 and an older style grill my gess (providing its factory) would be a 771/2. It should have a HP60 in it.
Leadmic
Old Dec 6, 2004 | 02:54 PM
SwOkcOffRoader
is the grill like the one on my truck(check gallery) or is the center inserts slightly different??? mine is a 76, most 75s and lower have more of a "flat" looking insert......
Old Dec 6, 2004 | 07:14 PM
Brian794x4's Avatar
Brian794x4
welp, all my excitement is all out the window now. I had to go back up there today to ease my mind, and it is a low pinion divorced tcase POS. So all my hopes of having a tough wheelin f150 for cheep is all out the window. basically the only diff that are worth hunting for, are the 78-79 then, correct? What about this later stuff, like mid 80's/90's...are they all low pinion too? Ah well, I thank you guys for all your input and knoledge, much appreciated
Brian
brian Felts
Jul 22, 2010 09:14 AM
bbrinkley
Jan 11, 2009 10:54 AM
Brian794x4
Sep 14, 2006 05:58 PM
Brians97F250Crew
Mar 19, 2006 08:42 AM
whoozeyourdaddy
Dec 31, 2004 06:02 PM
