1948 F2 8 lug pattern
Old Nov 30, 2004 | 07:47 PM
thomkat1966's Avatar
thomkat1966
Question 1948 F2 8 lug pattern
I found a 1948 F2 out in the sticks. The guy who owns the land said I could have it if I came and got it. My problem is that it has no wheels. I see that it has an 8 bolt lug pattern. Will any Ford 8 bolt pattern fit it or do I need something from the era? I'm kind of new at this but I'm looking forward to getting my hands dirty. Any advice would be helpful. Thanks
Old Nov 30, 2004 | 08:25 PM
51dueller's Avatar
51dueller
Yes any ford 8 bolt wheel will work up to the late 90's. I think dodge and chev even used the same pattern.
Old Nov 30, 2004 | 08:51 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Make sure the center hole is large enough to clear the hubs. The rear hubs especially.
Old Nov 30, 2004 | 08:59 PM
286merc's Avatar
286merc
One ton van and pickup non dually wheels have that nice big center hole as they go over a Dana 60 rear.
Old Dec 2, 2004 | 08:16 AM
SteV8e's Avatar
SteV8e
I switched from 17" wheels (2-piece) to 16" steel wheels from a 80's era F-250. I like the look and they were cheap ($25 each).
I believe that wheels from an F-250 or F-350 will work, any of the years up through'98, after which they went metric (170 mm). The wheels must be 8 lug on a 6-1/2" bolt circle. The hub hole is 4-3/4" diameter minimum, and the backspace (wheel mounting plane to inner edge of wheel) is 4-1/8". Also check that they will clear your brake drums. I know that C**y used the same hole pattern, but had a smaller center hole, which will not fit over your rear hubs.
Old Dec 2, 2004 | 10:59 PM
thomkat1966
Smile Thanks!
Thanks for the help guy's. I appreciate it.
Bubba Jones
1978 - 1996 Big Bronco
18
Feb 14, 2016 11:04 PM
classicrat52
Apr 19, 2015 06:43 PM
SuperDuty93
May 5, 2014 12:22 AM
hooperdoski
Jul 29, 2013 05:18 PM
Skirouled!
Jul 15, 2011 04:16 PM
