1978 - 1996 Big Bronco
Time for a new T-case.
Old Nov 30, 2004 | 07:22 PM
kameronth's Avatar
kameronth
Where can I find a good rebuilt BW 1356 manual shift for my 88. Mine is shot and I can not seem to find too many places that have them.
Old Nov 30, 2004 | 07:25 PM
andym's Avatar
andym
Cheapest source will always be a junkyard for stuff like that. They were in '87 & up Broncos and pickups up to F-350s. Some were electric shift, some were manual, and some were slip yoke, some were fixed yoke. Make sure you get the right one for your truck.
Old Nov 30, 2004 | 08:17 PM
kameronth's Avatar
kameronth
I don't want one from a junk-yard. I would like a new or rebuilt one. To many risks from one in a junk-yard.
Old Nov 30, 2004 | 08:42 PM
Jdenninger's Avatar
Jdenninger
Have you thought about rebuilding it yourself?? what is the problem your having with the current one?
Old Nov 30, 2004 | 08:49 PM
kameronth's Avatar
kameronth
It needs a new chain. When I give the truck gas it thumps real bad. It is not my tranny and the rear end is new. I am pretty good at things like that but I can not seem to find enough info to do it.
Old Nov 30, 2004 | 10:20 PM
Jdenninger's Avatar
Jdenninger
they're not to difficlt to do. do a search on here there are links that explode out hte transfer case. that is most of the info you will need. for the most part the case just houses 2 spindles with gears, a chain between them and 2 forks on the main to engage/disengage 4wd and hi/low gear. i did mine myself in a day. truck was stuck in low gear. fork as broken and oil pump seized. wasn't tooo bad.
Old Nov 30, 2004 | 10:45 PM
kameronth's Avatar
kameronth
Ya, that is what I will probably do. I already have an exploded view, I was just wondering if there were step by step instructions.
Old Nov 30, 2004 | 10:54 PM
body9599's Avatar
body9599
check this thread
https://www.ford-trucks.com/forums/s...d.php?t=302161
Old Dec 1, 2004 | 12:07 PM
andym's Avatar
andym
If you want to go that route, then take a look at these links as well:
http://www.drivetrain.com/transfercasesparts.html
http://www.wildercafe.com/fordtech/
Old Dec 1, 2004 | 01:08 PM
dammford's Avatar
dammford
do it your self...or ebay!! it's not that hard to do your self!!
Old Dec 1, 2004 | 06:56 PM
kameronth's Avatar
kameronth
What size torx bit do I need to it open? I have heard both 45 and 50? Also I was told that I needed to use 80w90 in my t-case because it gets so hot out here that the ATF is too thin, and that is does not get cold enough so it will be fine. Should I do that?
Old Dec 1, 2004 | 06:58 PM
body9599's Avatar
body9599
T50...can't vouch for the 80w90 oil though.
Old Dec 1, 2004 | 07:52 PM
kameronth's Avatar
kameronth
This guy says that it is a t-45? Is that the only special tool I need for this?
Old Dec 1, 2004 | 09:18 PM
body9599's Avatar
body9599
I used a T50...you'll also need a really good pair of snap ring pliers and ~31-32 mm socket...or whatever size SAE that is...to get the main nut off (this might be the case only in the flange version output shaft).
dlehmann
2009 - 2014 F150
Oct 1, 2016 11:48 AM
cdwoodcox
2009 - 2014 F150
Aug 22, 2016 06:48 AM
MER
Dec 15, 2008 03:02 PM
Trevor1
Jul 19, 2006 02:31 PM
masterbeavis
Apr 23, 2002 03:26 PM
