4 X 4 Help please
Old Nov 30, 2004 | 06:05 PM
homeinoz's Avatar
homeinoz
Red face 4 X 4 Help please
I have a 79 351m with a 4 speed manual transmission. I have never owned a 4 wheel drive, so i'm kinda dumb when it come to them.
Can someone please tell me what the transfer case shift pattern is?
Thanks, Tom
Old Nov 30, 2004 | 06:43 PM
andym's Avatar
andym
Well, it depends on what transfer case you have. There's been some discussion on this before - have you tried a search?
It's a lot easier than you probably think it is. You should have manual lockouts on the front hubs. The dial locks the wheel to the axle. If it's unlocked, the front axle shafts aren't connected to the hub and don't drive the wheel. If they're locked, you can switch back & forth without getting out of the cab.
A lot of people lock the hubs in when they know they might need them, and then just switch the transfer case back and forth when they need 4x4.
Old Nov 30, 2004 | 07:58 PM
85e150's Avatar
85e150
No sticker in the cab on the visor or nuthin?
If you are new to 4x4, I guess the 1st thing to know is NOT to run 4x4 on dry or even wet pavement. Only when you are going to need 4x4 traction, like mud or snow should you be going into 4x4. 4x4 on dry pavement? "Clink, bang, that'll be $400, please".
Your transfer shifter might go in a straight line:
2H
N
4H
4L
Or reverse of that.
Good luck.
