1978 - 1996 Big Bronco
Ignition lock and switch problem/need advice
Old Nov 30, 2004 | 03:27 PM
likemybronco's Avatar
likemybronco
I have a 92 Bronco. The problem that I have concerns the nylon linkage between the Ignition lock and Ignition switch. It seems as though it has busted into 2 pieces. I pulled the ignition switch and lock out. The only item in my way to get the nylon linkage out looks to be the gear that the ignition lock turns. I am not sure how to remove this gear. Any Ideas?
