Code P0172 & P0175 problem
Old Nov 30, 2004 | 01:24 PM
bigmikeok's Avatar
bigmikeok
I have a problem with this code coming up all the time and I need to know if it might be the fuel pump. My mechanic tested the fule pressure and that it was to spec but after the engine was shut off the fuel pressure dropped emmediately. He says it may be the fule pump or an injector.
Does anyone know how to test to see which it is and does anyone know how to test injectors to see if they are leaking?
Old Nov 30, 2004 | 02:37 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Mike, since those codes show rich on both banks, I would rule out a single injector leaking, although it still could be one leaking on each bank. It very well could be a bad fuel pressure regulator. If you pull the vacuum line to the FPR, and there is raw fuel present, then it's bad (and leaking fuel into the intake manifold).
Old Nov 30, 2004 | 02:59 PM
bigmikeok's Avatar
bigmikeok
thanks I'll try that. If you think of anything else let me know.
1L243
Jun 13, 2015 08:50 AM
mikejaros
May 5, 2015 04:44 AM
Sexygumby
Mar 4, 2014 07:31 AM
Jakex1990
1983 - 2012 Ranger & B-Series
Aug 31, 2012 07:21 AM
conrad kornell
Jul 18, 2003 10:03 PM
