1978 - 1996 Big Bronco
Replace a E4OD with a 5-speed manual? possible?
Old Nov 29, 2004 | 11:58 PM
JetBlackBronco's Avatar
JetBlackBronco
is there a way i could put a 5 speed manual trans in my '91 bronco?
its got a 302 and i believe a E4OD, and it goes good, but gets bad mileage(4:11 gears dont help either), but i really want a standard transmission, i miss the one from my old pickup(1990 F150)
i dont know how feasable it is, but it sounds like a good summer project. so if anyone could give me any pointers or insight, i would appreciate it.
Old Nov 30, 2004 | 12:51 AM
aurgathor's Avatar
aurgathor
Might be easier to find a Bronco with stick since you need to change quite a few things. I don't think MT will get significantly better mpg since the Bronco is a fairly heavy and not very aerodynamic car with a big frontal area. I was thinking about the same thing, but after reading some people's comment (i.e.: "never again" ) I'll stick to whatever I have for now. I plan to buy a Bronco with MT in the next couple of years, however.
If you stick to your intention, you probably need a donor car (i.e. F150) where everything you need is functional. Some people had done it.
Old Nov 30, 2004 | 10:45 AM
Kemicalburns's Avatar
Kemicalburns
yes it can be done. the prefered Tranny to swap over would be the ZF 5speed. its a very strong manual tranny, way better then the m5od that came stock in most broncos/f150's. you can find the zf in most 90+ f250's. Do a search on zf swap and im sure you questions will be answered.
good luck
IHdieselfan
Jul 4, 2015 05:50 PM
1800joedaddy
Jan 1, 2014 08:51 PM
mrrish79
Oct 30, 2013 07:46 PM
turboguy
Mar 13, 2005 04:36 PM
