2100 motorcraft problem...
Old Nov 29, 2004 | 10:59 PM
nick71F100's Avatar
nick71F100
I just finished re-building the 2100 series motorcraft carb on my 71 F100 302, Ive found that now I have fuel spraying thru the top of the carb and my gas pedal is sticking to the floor, although I LOVE working on my Ford, I'm an extreme shadetree mechanic, Id appreciate insight from some of the wiser ford guys.
Thanks a lot!!
Old Nov 30, 2004 | 04:56 PM
heel&sole's Avatar
heel&sole
As for the pedal, are you sure you hooked up the return spring and other throttle linkages correctly when you put the carb back on the manifold?
Assuming the gaskets are on properly, the fuel spraying could be caused by not making sure the wire that holds the float in place is clipped in place in the indentation on the needle seat.
ford-power-f250
22
Apr 27, 2024 10:31 AM
ldman
May 30, 2014 05:56 PM
MarkyMark-Ford
Nov 24, 2011 10:09 PM
89chargedbird
Jun 6, 2005 07:38 AM
