0320 code mystery
Old Nov 29, 2004 | 08:36 PM
kramer5's Avatar
kramer5
0320 code mystery
My 96 F150 computer logs a 0320 trouble code. The truck will run fine for 3-20 mi. then the engine just quits for 2-5 seconds. Then the truck will run nornally for the rest of the day. My dealer mech. is stumped everything checks good. Any similar problem out there?
Old Nov 30, 2004 | 06:32 AM
EPNCSU2006's Avatar
EPNCSU2006
It's an intermittent problem, so it will be hard to find. P0320 states: Ignition/Distributor Engine Speed Input Circuit. So that should narrow down the problem for you. It could be the pickup in the distributor, or the TFI module possibly as well. It could just be a loose wire and when you hit the right bump it kills the engine for a few seconds. Maybe try wiggling the wires near the distributor and the TFI module with the engine running to see if you can get it to stall.
Jay87LX
15
Sep 17, 2016 09:22 PM
crewcab96
May 27, 2014 11:38 AM
kevinbarnhill
Modular V8 (4.6L, 5.4L)
Apr 23, 2011 03:10 PM
ymountainman
Aug 8, 2010 07:11 PM
So-Cal Sancho
May 26, 2009 07:06 PM
