Power Door lock button
Old Nov 29, 2004 | 07:23 AM
m_disco's Avatar
m_disco
I'm having an interesting problem with the power door lock switch on my drivers door (99' XLT SOCH).
Whenever the door is open and I push the unlock button, nothing will happen. I push the lock side and it locks. If I close the door, then the button will unlock the doors. It's rather annoying to have to have the door shut to ulock all the doors. It also is only doing this on the drivers side.
Anyone else have this problem?
Old Nov 29, 2004 | 12:22 PM
bulldog3531's Avatar
bulldog3531
you might have a loose connection to the switch. take the door panal off and you will be able to see it.
Old Nov 29, 2004 | 03:29 PM
sjwoody's Avatar
sjwoody
On a 94 Exp, I found all the switches and wiring good, but the actuator itself was bad. The dealer wants about 68 dollars (for the '94) and the salvage yard wanted 20 dollars. No one was available at the salvage yard (lunchtime), so I went home, removed the actuator, and after breaking it apart, found the little motor inside probably had a dead spot on it. I hooked it up directly to a battery and let it run a minute, I used a ty-rap and put it back together and it works fine. I don't know how long this will last, and I don't know if this will help you, but good luck.
Old Nov 29, 2004 | 04:10 PM
87 XLT's Avatar
87 XLT
Sounds like a wire is going open where it flexes in the door jamb. Take a look at your wiring diagram so you know which wire to look at, then remove the drivers side kick panel & check that wire.
demerton
Jul 18, 2012 08:00 PM
Nite Ranger
1983 - 2012 Ranger & B-Series
May 31, 2010 12:13 AM
jonboy88
20
Jun 12, 2006 03:35 PM
jlitz
Mar 16, 2004 11:51 PM
