Bronco II Ford Bronco II
89 2.9 questions
Old Nov 28, 2004 | 09:23 PM
mike327's Avatar
mike327
Question 89 2.9 questions
Hello I have a 89 BroncoII That starts fine when cold but it has to spin over a while and press the accelerator peddle to get it to start when hot. Not a big problem but I know it is not right. A while being about 5 to 10 seconds. It also has a rich smell at the exhaust. A little history, new heads, lifters, 02 sensor, plugs, cap, rotor, wires, fan and clutch assy, oil pump, cleaned the throttle body. It is not giving a check engine light. I have not checked for codes. Also any easy ways to trouble shoot fuel gauge and oil psi gauge. I changed oil sender but it still would not work. Fuel ?????. Checked oil with a manuel gauge. Thanks for any help.
Old Nov 28, 2004 | 09:31 PM
RomerB2's Avatar
RomerB2
Mine has the same problem, they told me to check for fuel pressure (which I haven't done ) and also check vacuum lines.
Old Nov 28, 2004 | 11:07 PM
Monty06's Avatar
Monty06
2.9 q&a
check your timing one thing to know b2 don't have a check engine light
Old Nov 29, 2004 | 02:25 AM
turborich's Avatar
turborich
mine has a check engine light.
Old Nov 29, 2004 | 09:56 AM
Aggie05's Avatar
Aggie05
i have an 89 BII and mine has a check engine light too.
Old Nov 29, 2004 | 11:27 AM
Monty06's Avatar
Monty06
sorry forgot this small sentence from 88-90 b2's have a light
anything from mid 88 down don't sorry forgot
Old Nov 29, 2004 | 04:06 PM
mike327's Avatar
mike327
The engine is spinning fine not like timing is off. Set at 10 deg.???
Old Nov 29, 2004 | 08:10 PM
BigBill's Avatar
BigBill
I would guess that it is the fuel pressure. I own an 89 bronco 2 and I have that problem. Its about time for that engine overhaul =(
Old Nov 29, 2004 | 08:11 PM
Ken00's Avatar
Ken00
Sounds like a leaking FPR, check the vacuum line for gas after it's run for a few and then shut off.
Old Nov 29, 2004 | 08:52 PM
mike327's Avatar
mike327
FPR, I think that is a fuel pressure regulator? I will check it out in the am. I also wish I would have went ahead and pulled the engine and done a overhaul. That oil pump was a job.
Old Nov 29, 2004 | 09:12 PM
Ken00's Avatar
Ken00
Thats correct.
Old Dec 4, 2004 | 11:32 AM
ron46's Avatar
ron46
i had an 86 2.9 with same problems. there is a sensor just behind the gooseneck that looks similar to a water temp send sensor. what it does is when the engine is hot or cold, it tells the brain to either richen,for cold starts, or lean it out for hot starts. my analogy of it is, like a choke on a carb. motor. since the newer trucks are EFI you still need to have a little richness on cold starts.do not buy a temp.sensor,as they are not the same.ron46
Eloscarin89
Oct 28, 2016 09:40 PM
Carmello Castellano
Jan 28, 2015 10:21 PM
77F-150
Jul 12, 2014 11:46 PM
liv2roc
Jan 6, 2013 11:23 AM
n4ynu1010
17
Aug 4, 2012 09:05 AM
