351m Motor Mount ?
Old Nov 28, 2004 | 07:26 PM
79 posi's Avatar
79 posi
351m Motor Mount ?
I may be putting a 351m from a 2wd 4 spd f-150 into my 4spd 4wd f-150.
First, will the motor mounts from the 2wd work in the 4wd? I currently have a 300-6 now.
Second, will I need to get a different oil pan - rear sump vs front sump?
Just wanted to see if it would be worth paying a little extra for the whole pickup if I could use the other parts, put the 300 back in the 2wd and sell it again.
Thanks
Old Nov 28, 2004 | 09:10 PM
79 posi's Avatar
79 posi
Years may help as well? 2wd is a 78, 4wd is 79
Old Nov 29, 2004 | 10:37 PM
74 F100 351m's Avatar
74 F100 351m
If there is a 300 in the 4x4 the 351m will not set on those mounts on the frame. I would say yes you need a rear sump pan.
Old Nov 29, 2004 | 11:40 PM
79 posi's Avatar
79 posi
Let me rephrase - I realize the 300 and 351 are different mounts. I meant to ask whether or not I can take the 351, including the mounts, out of a 2wd and drop into the 4wd, or will I need to get 4wd 351 mounts?
Old Nov 30, 2004 | 06:27 PM
zwinstead's Avatar
zwinstead
The 4x4 and 2wd frame towers are totally different.
