Missing... No Power!!!
Old Nov 28, 2004 | 05:34 PM
DirtRacinStroker's Avatar
DirtRacinStroker
Post Missing... No Power!!!
I have a 2000 F250 CC with auto and only 75000 miles. My problem is that it seemed to start out as a cough at higher rpm or cruise speed (after changing the fuel filter about a month ago). It gradually got worse. Then today coming home (about 270mi trip), it has gradually lost all power and is missing bad, not smoking though. I pulled the fuel filter, it was decently clean, didn't see any water either. Don't have anything to read codes. Would it be the CPS?
Been reading here for the last couple months trying to learn all I can. Thanks
Old Nov 28, 2004 | 05:46 PM
Fire Rooster's Avatar
Fire Rooster
Take it to checker auto or a similar parts store. Have them read the codes. Very well could be the CPS.
Fire Rooster
Old Nov 28, 2004 | 06:56 PM
DirtRacinStroker
Thanks for the reply Rooster. Greatly appreciated. Everything is closed now, so I'll get that done tomorrow.
Probably more questions to come.
Thanks again
Old Nov 28, 2004 | 07:38 PM
Ran440's Avatar
Ran440
DirtRacinStroker
Doesn't sound like CPS to me. Sounds more like it could be the wiring harness going through valve covers to injectors. I hear they can fry due to a poor connection.
Randy
Old Nov 28, 2004 | 07:47 PM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by Ran440
DirtRacinStroker
Randy
Yeah and here's some pictures to help you along.
https://www.ford-trucks.com/forums/s...d.php?t=278697
Old Nov 28, 2004 | 09:43 PM
DirtRacinStroker
At first I thought it may be water, kinda acted the same. Fueled up and added some DK, hoping it would get better. Longer I ran, the worse it got. About 5 to 10 miles from home (lucky me), it would hardly pull itself flat on the floor - didn't really matter what position the throttle was as long as it was down. Boost wouldn't increase much til I had a little speed (down slight grades or on a flat) Also thought it might be tranny, but put it in neutral and still the same. Take off was a choreand would hardly take off.
Run everything through my mind to what could normally be, but that doesn't seem to pertain here. lol I checked my oil when I fuel'd up, it is up (just changed it about 700 mi ago from Mobil Delvac 1300 to Shell Rotella T). After running everything through, it would just about have to be the injectors. Oil pressure is good and oil is clean.
Thanks for the replys guys. I'm new to diesels and I'm kinda lost. Not so much as mechanic-ing (been doin' that since I can remember, not outa choice but need). Worked on big trucks some...PSD is new to me, and I need help...lol
Trying to keep from going to dealer if at all possible. $$$
Thanks guys, greatly appreciated. I'll try to check these items. Keep ya posted and hope it may help others.
Old Nov 28, 2004 | 11:19 PM
Pikachu's Avatar
Pikachu
Two things come to mind in addition to the cam sensor, bad fuel and possibly a bad throttle position sensor.
Old Nov 29, 2004 | 04:29 AM
DirtRacinStroker
Exclamation
Other than the bad fuel idea (I've gotten fuel, all fill ups, about 6 times since filter change at 4 different places) would these things show up in codes?
Old Nov 29, 2004 | 03:24 PM
DirtRacinStroker
Well, ended up taking to dealer...........they said it spit out a bunch of codes. They were gonna install new batteries and then pull valve covers. They said it may be wiring or injectors. We'll see, and keep ya up to date.
Old Dec 2, 2004 | 07:39 PM
DirtRacinStroker
Well, here's the update.
Picked it up last night at the dealer. They had to do some work with the wiring under the valve covers and replace an injector..(My hat is off to you guys, the info in the your replies gave me some knowledge up front to prepare me for the dealer)........best news.. Engine warrentee covered those repairs.....Dealer also stated he got a "code" for 3rd gear in the tranny but alot of times when the batteries are bad.....it gives this code..(I knew one battery was bad) So I have 2 new batteries now. This dealer seems to be honest and upfront........even before he hooked it up to the computer, he had told me that it may be "covered".
It goes back in the morning........idling rough and missing.....seems to have a fuel leak which wasn't there before...... They said no problem..bring it to them........lol good deal.
Thanks guys, greatly appreciated. Gonna read some more and learn all I can.
1984F-150_351HO
6.4L Power Stroke Diesel
Feb 21, 2015 03:00 PM
fiftyfordfloored
1997 - 2003 F150
Feb 5, 2013 01:57 PM
ruskc1
1997 - 2003 F150
Feb 28, 2010 06:54 AM
kbatku
Dec 31, 2008 10:40 AM
super_ranger
4 Cylinder Engines
Sep 9, 2004 10:14 AM
