Removing second cat
Old Nov 28, 2004 | 05:33 PM
Marc150's Avatar
Marc150
Removing second cat
Would there be any benefit from removing the second cat and leaving the first on?? I dont believe theres anything wrong with them. Would there be any performance/sound gain?? I already have a performance high flow muffler /w a 3" tip. Its got a rumble, but I would like more and thought that removing the second cat would make it louder. OR SHOULD I LEAVE WELL ENOUGH ALONE??
Old Nov 28, 2004 | 10:12 PM
MemOrex's Avatar
MemOrex
I wonder the same thing.... Whats the deal with 2 cats anyway? I'm pretty sure it will make a sound gain. Oh well, mines coming off soon....maybe tomorrow
Old Nov 29, 2004 | 09:10 AM
Marc150's Avatar
Marc150
I think the first one is a pre cat, not sure what that means. If ya do rip it off, lemme know how it sounds and if you notice any power/mileage gains. Just hope it dont stink !! What about the air pump, maybe we could rig it into a little supercharger .
Old Nov 29, 2004 | 04:47 PM
MemOrex's Avatar
MemOrex
Damn, its cold and rainy outside, so cat is still on. It might smell just a little, but not too much since that other cat is still there.
Old Nov 29, 2004 | 06:13 PM
Saurian's Avatar
Saurian
I was led to understand that each catalytic converter is better able to focus on a certain form of emissions, but I don't know for sure anymore. Anyways..the precat just Y-pipes and doesn't clean up the emissions quite as much.
Old Dec 30, 2004 | 09:05 PM
MemOrex's Avatar
MemOrex
Sooo, I STILL haven't took it off..yea I know, I'm lazy. Anyways, while looking down there, it looks kinda tricky. After the air tube connects to the pipe, the pipe kinda 'flattens' then goes back to normal, then enters the second cat. So, i'm gonna cut it off RIGHT when the pipe enters the second cat. BUT, that big-horizontal-frame-bar-thing is kinda in the way. (I dont know what its called, but it goes across the bottom of the truck).
It's kinda tricky since I will be using a saws-all. lol. And the local shops won't do it soo...
Old Dec 30, 2004 | 11:17 PM
Saurian's Avatar
Saurian
The second one doesn't have as much surface area for catalytic conversion, as well as no air injection for the system either. The second one is the primary one. You might stink, you might not. Mine doesn't..which is odd. Generally, you'll be stinky.
Old Dec 30, 2004 | 11:58 PM
RICE H8R's Avatar
RICE H8R
Mine has only the first cat on it...second one was cut off when I got the pickup. I'm pretty certain it makes it considerably louder without it. My buddy has a '96 and had both cats straight piped, and mine with one cat and a FM 40 was considerably louder. I'd say remove it...can't hurt anything. It'll sound much better IMO.
Old Dec 31, 2004 | 11:37 AM
MemOrex's Avatar
MemOrex
Oh well if it smells, it already does lol. Yea, I had straight pipe and both cats and its not loud at all. The second cat does look like the main one. The first one might do a little conversion, but it looks like it just y-pipes.
Old Jan 1, 2005 | 05:41 PM
Marc150's Avatar
Marc150
There is always Catco converters on Ebay for cheap, I was thinking about either replacing the second cat with it or taking both out, putting on a y pipe and a high flow cat. With the high miles on my truck, I dont think it will hurt anything, cats are prob not as efficient as they used to be
Old Jan 3, 2005 | 10:11 PM
1994ford's Avatar
1994ford
I pulled the second cat off my truck a couple years ago and I'm impressed with the sound. I have no muffler and it's just a pieced together system so it surprises people when they hear my truck. I'd say its just right for loudness too. Rip the cat off IMO.
Old Jan 3, 2005 | 10:59 PM
MemOrex's Avatar
MemOrex
Any tips on easy-removal of it? Did you use a torch? Saw?
Old Jan 4, 2005 | 12:15 PM
akford351's Avatar
akford351
I removed mine manually with a hacksaw...
Would've been much easier with a sawzall.
I'm currently running a 3" SI/SO Dynomax Race Bullet and it sounds great... deep and fairly loud.
http://www.angelfire.com/ne2/ray21_f...omaxBullet.mp3
Old Jan 6, 2005 | 04:11 PM
nick88f150's Avatar
nick88f150
I just took my second one off....and it was a pain w/o a Sawzall. I used an angle grinder with cutting disc for most of it. It helped to undo the manifold so I could twist and move the pipe around. Either way it took a lot longer than it should have. I'm pleased with the results though. Right now I have 1 cat. going into 2.5" pipe, 18" glasspack. It then splits to dual exhaust, with 4"x24" tips. With that second cat on it sounded pretty "ricey" but after I took it off the truck hasa bit deeper sound. Sounds pretty good when I get on the gas. It also helps that my G.P. is probably burnt out by now.
Old Jan 6, 2005 | 07:04 PM
MemOrex's Avatar
MemOrex
Argh!, I got the sawsall out today and *tried* to do it, but theres no room down there... The frame rail is in the way, and I don't want to cut the pipe where the Air Pipe goes in. I actually went at it better with a hacksaw, but I got tired sooooo, Im just gonna torch it off. Stupid cat....lol
