Major Project!!
Old Nov 28, 2004 | 12:51 PM
IluvDonuts's Avatar
IluvDonuts
Major Project!!
Ok i have a 1992 F-150 5.0L V8 Auto 4x2, and im wanting to drop a 460ci engine in it, convert it to a 5spd manual, and 4x4. First off, is all this possible. if so how much would it cost me. plus is there any certian order i need to do it in.
Old Nov 28, 2004 | 01:16 PM
andym's Avatar
andym
First off, anything's possible. It's just a matter of skill and money.
You've got a couple decisions to make. Do you want the beefier 3/4 ton axles? You're going to be swapping in a 3/4 drivetrain. Depending on how hard you run this rig, you might need the stronger axles to go with the big power plant. Also, do you want a solid front axle or a TTB?
If you do, you're going to end up with basically a 3/4 ton truck that's going to cost you a lot more than it would just to buy a 3/4 ton truck. Except with a weaker frame. If you just want to do it because you can, then there's no problem with that.
No matter what you decide, you're going to need to buy a parts truck. At some point, you're probably going to need to fab something up, so you should have access to a welder.
If you buy a 3/4 ton or 1 ton 4x4 truck with a 460 and a ZF, you're going to get all your parts in one place.
Old Nov 28, 2004 | 03:33 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Problem solved, and didn't we save a bunch of work. Sell yours if it is not what you want, buy what you want.
Old Nov 29, 2004 | 06:21 PM
IluvDonuts's Avatar
IluvDonuts
Bump
I quote.
