There are no other engines that will swap in easily.
You could use a 4.6 or 5.4 out of a similar truck but everything is different.......transmission, engine mounts, alternator, P/S pump, alternator, exhaust, wiring, PCM etc.
If you had a donor truck it wouldn't be too bad but otherwise it will be a ton of work.
