92-96 f-150 e4od question?
Old Nov 28, 2004 | 09:46 AM
Jrock909's Avatar
Jrock909
I was wondering why on the 92-96 f-150s and all the way through the f-350 models that are equipped with the E4od trannies downshift on hills? I hate having to shut the overdrive off to go up a hill
Old Nov 28, 2004 | 12:21 PM
IluvDonuts's Avatar
IluvDonuts
damn it i hate it too! 92 f-150 here. im converting everything to a 5spd 4x4 lol >.<
Old Nov 28, 2004 | 12:24 PM
SoCalDesertRider's Avatar
SoCalDesertRider
The trans downshift going up hill when the hill is steep enough and vehicle speed slows down enough that engine speeds get too low for that gear and lower ratio gear is needed to pull the hill. This is normal operation for any electronic transmission.
On a manual tranny, you should downshift it when the rpms and vehicle speed start to drop off so you don't lug the engine pulling the hill.
On non-electronic auto trannies, they will down shift when the gas pedal is pressed down far enough trying to pull the hill that the kickdown mech is tripped.
If your auto tranny is hunting between gears going up hill, you should lock out the overdrive or shift it down manually, as gear hunting creates heat and can lead to transmission failure.
Pulling hills in too high a gear with the engine lugging and the gas pedal on the floor wastes gas and is not good for the engine or transmission. You will get up the hill faster in a lower gear with the engine operating in it's powerband at part throttle.
In a truck with a healthy engine and transmission, too much downshifting on hills that are not that steep can be caused in part by a truck that has too high (numerically low) an axle ratio for the weight/load of the truck or the diameter of the tires.
