EGR disconnect
Old Nov 28, 2004 | 08:39 AM
firegod619's Avatar
firegod619
EGR disconnect
When you disconnect the EGR plug do you need to remove the plate or will it work with out removing it and just unpluging it.
Old Nov 28, 2004 | 10:09 AM
huntercgr's Avatar
huntercgr
This should answer all your questions.
https://www.ford-trucks.com/forums/s...d.php?t=282640
Old Nov 28, 2004 | 06:58 PM
jdadamsjr's Avatar
jdadamsjr
FG,,,
since you're in Florida & not the CARB centric Kalifornia,
u will only have to pull the plug and you should be good to go...
Old Nov 30, 2004 | 02:15 PM
wizard's Avatar
wizard
i live in se texas and had been having a problem with my 03 f250 6.0 not "taking off" from a dead stop very quickly unless i put on the brakes and ran the rpm's up alittle....just unplugged the EGR today to see what would happen and it seemed to have done something to help that problem...now when i hit the pedal it takes right off with no sluggish behavior at all...
Old Nov 30, 2004 | 02:17 PM
mrxlh's Avatar
mrxlh
Is it necessary to unplug the egr if you are using a tuner? (superchips 1704)Ryan
Old Nov 30, 2004 | 02:57 PM
ninelives 59's Avatar
ninelives 59
the egr disconect worked better with my tuner box..The turbo lag was gone and smoked alot less on start up and decell..I found out that the 04 truck might get a check engine light because a friend had done the same and his light came on..
Old Nov 30, 2004 | 02:59 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
The CEL will only illuminate if the truck is running on a California-emissions flash.
