antifreeze usage
Old Nov 27, 2004 | 06:24 PM
77hiboyboy's Avatar
77hiboyboy
antifreeze usage
On my 00 PSD with 98xxx miles, I have noticed it takes some antifreeze, I've only had the pickup for around 4k miles and it was on the "low" part of the overflow tank, I filled it, right after I bought it, and it is down to the "low" section again. It doesn't go any lower, just stays there. I have a little bit of warantee left, anyone else have this problem??
Old Nov 28, 2004 | 05:39 AM
blackf3504dr's Avatar
blackf3504dr
If you have some warrenty left take it in and have it looked at , then it will be on record as an existing problem after the warrenty runs out . It could be a number of things , so have it checked out while still covered .
Old Nov 28, 2004 | 10:56 PM
77hiboyboy's Avatar
77hiboyboy
will do, thanks.
