speedometer/odometer/trip counter
Old Nov 27, 2004 | 12:34 PM
Nairobi's Avatar
Nairobi
Unhappy speedometer/odometer/trip counter
1997 Ford Ranger: Sppedometer stops after about ten minutes of driving. This is not altered by hot or cold weather, wet or dry weather or on road or off road driving.
I changed the sensor in the rear diff but the same symptoms continue. Mechanics have checked the cable and the various connections to no avail.
Any suggestions would be appreciated.
Old Nov 29, 2004 | 04:30 PM
Thomaswh3's Avatar
Thomaswh3
I have a 98 Ranger and the same thing happened to me. The ford dealer said it was the speedo head and wanted $600 to replace it. I went to a salvage yard and bought a used instrument cluster for $50. I changed just the speedo-tach part. I put it part way back together and took it for a ride. After about 7 or 8 miles it stopped working. I then changed just the instrument cluster housing, it has the electrical circuits on the back. I used my original gauges and speedo to keep my milage right. I have driven about 2000 miles so far and it is still working. I think that was the problem.
Old Nov 29, 2004 | 05:31 PM
Nairobi's Avatar
Nairobi
Thomaswh3: Thanks for the information. I will give that a try and let you know what happens. This has stumped all of the mechanics that I talked with.
Old Jan 26, 2005 | 12:40 PM
Nairobi's Avatar
Nairobi
Thomaswh3
Your advice regarding the erratic performance of my sppedometer/odemeter was right on the money. I obtained a replacement instrument cluster housing and the problem has been resolved. Thanks a lot.
