Cheap Performance?
Old Nov 26, 2004 | 09:08 PM
75diesel's Avatar
75diesel
Cheap Performance?
I have a 95 F-150 4X4 w/e4od and 5.8L, 3.55 gears and 31-10.5 tires, custom 2 1/4 duals. I have added an Accel super coil, K&N filter, adjusted the timing to 10 deg btdc (the right way), re-gapped the plugs to .055" (on new tuneup parts), reset min idle, re-programmed speedo, and am running castrol full synthetic 5w-30. Is 16mpg too little with this combo? The biggest difference I noticed was when I re-gapped the plugs at the same time I replaced the coil, both in performance and mileage. I guess all I have to ask is if there are any more "cheap" mods I can do to increase mileage, other than put a block under the go pedal.
Old Nov 26, 2004 | 10:45 PM
frederic's Avatar
frederic
16mpg is pretty good. You'll find that most folks here are at there, or less, for gas trucks.
Old Nov 27, 2004 | 01:14 AM
GST97's Avatar
GST97
Ya, I would be extremely happy with 16 MPG. Even after changing a failing EGR, I am still only seeing 10 MPG. I am starting to think maybe the cat is clogged up or something (original cat for all I know), as everything else seems to check out... and it runs just fine... just that 10MPG is going to bankrupt me
-Chris
Old Nov 27, 2004 | 01:25 AM
optikal illushun's Avatar
optikal illushun
cheap performance? add some nitrous oxide. best bang for the buck. personally i think u wasted some $$ on those mods but whatever. might wanna try some electric fans.
Old Nov 27, 2004 | 05:55 PM
75diesel's Avatar
75diesel
I was refering to $100 and less for things to install, not 400-500$, and thank you very much but they all have added to the 16mpg I'm getting, thank you very much!
Old Nov 27, 2004 | 08:53 PM
ford5.8's Avatar
ford5.8
My 96 5.8 is up to 16mpg also..I thinks thats good,I did a full tuneup and a free flowing exhaust. Was that accel super coil hard to install? I wonder if it would make a difference on mine..?
Old Nov 27, 2004 | 09:57 PM
jwtc36's Avatar
jwtc36
Wink
Even though optikal illushun may have come across as a tad rude.....I do have to agree w/ him on the electric fan idea....less drag on motor will increase power and mileage. I'd be estatic w/ 16mpg though....I'm guessing I'm getting about9- 10 mpg right now
Old Nov 27, 2004 | 10:35 PM
ATC_250SX's Avatar
ATC_250SX
take the 16 and run it, I was lucky to get 10-12 on the highway with my truck, and that was with the tailgate down, wind to my back, going down hill. all ive done to it is, K&N open element, no cats, flowmaster 40, with duals after, MSD Blaster 2 coil. no smog pump, and its punched .040 over <- (new news to me just found out) and this is on an 87 f-150, 351w 4bbl 4x4. so if i were you id be happy with 16
Old Nov 27, 2004 | 10:44 PM
Blurry94's Avatar
Blurry94
You don't get any better gas milage with the tailgate down. My trap speeds at the track are slightly higher when I leave the tailgate up.
http://popularmechanics.com/automot...ss/index5.phtml
http://www.awtrucks.com/tailgateup.htm
Old Nov 27, 2004 | 11:36 PM
75diesel's Avatar
75diesel
Basically, on a 95 F-150 5.8L the coil is held down with four 5.5mm screws, takes something like two minutes to change, Accel coil part# ACC-140012 $39.88 at Summit Racing.
As for the cooling fans, that was going to be the next thing. Anyone know of a direct fit fan(s) for a 95 F-150 w/ac? I just don't like the cheezy plastic tie-straps that universal fit fans use. I have had to fix too many holes in radiator cores. (I'm a mechanic for a living and I just hate to have to re-do anything.)
Does anyone have thoughts on manifold replacement style headers? I'm thinking about the ones that Summit racing offers, part #SUM-G9036. Just asking.
Old Nov 27, 2004 | 11:49 PM
Blurry94's Avatar
Blurry94
As far as the fans go...Flex-A-Lite 295's will work very well. For a truck, I wouldn't go with anything smaller.
The Summit headers will work better than the stockers, and give your exhaust sound a more commanding note.
Old Nov 27, 2004 | 11:51 PM
optikal illushun
flex-a-lite black magic fans are a direct drop it. dont have the model off hand, sorry. they are quiet expensive tho. u can always get a 16" fan and mount it in ur stock shroud with a good mount to the outside of the rad not the fins...
Old Nov 27, 2004 | 11:59 PM
75diesel's Avatar
75diesel
Good idea mounting to the shroud, hadn't thought of that. Might have to look into that. Suppose a pusher up front would be a good idea too, or just decrease natural flow?
Old Nov 28, 2004 | 12:20 AM
Blurry94's Avatar
Blurry94
The 295's come with their own molded shroud, and they (twin 13.5" fans) cover the entire radiator. They are made for trucks and they pass almost twice the air as the single black magic fan. They ramp up slow so they don't tax your electrical system and you can adjust the temp settings to command when you want the the fans to come on. I run this setup on my supercharged 351 and have never had a cooling issue on the street or at the track.
Old Sep 21, 2006 | 04:53 PM
jhollie's Avatar
jhollie
Best electric fan going is a lincoln mark viii!! How about 4000 cfm vs 2800 from flexalite!! This is a great built and flowing fan made by siemens.
matpasch
Sep 23, 2009 05:39 PM
Frank Lang
May 19, 2004 11:03 PM
Frank Lang
May 13, 2004 10:44 AM
Like M. Fords
Jun 14, 2002 08:38 AM
XLT4Banger
1983 - 2012 Ranger & B-Series
17
Apr 7, 2002 06:31 PM
