Clutch Problem
Old Nov 26, 2004 | 01:06 PM
Bronco2Nic's Avatar
Bronco2Nic
Question Clutch Problem
I finally got my truck all back together and running but there still is one problem. My clutch dose't seem like it's releaseing fully. I can push the clutch all the way in and its hard to get into 1st-2nd-and reverse. All the other gears are fine. Sometimes when I push the clutch in there is a scraping sound. It isn't a constant sound though. The sound is also in relation to the RPM. If I rev the engine then the frequence increasses. If you can help me with this problem then that would be greatly appreceated. Thanks for any help.
Old Nov 26, 2004 | 07:25 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
my ford bus does the same thing, i replaced the clutch last year and i have a hard time shifting, but my clutch action in almost at the floor, the only thing it could be is that it needs adjusted some more, try adjusting yours both ways and see what feels better.
