fires but won't start
Old Nov 26, 2004 | 11:21 AM
tandrus73's Avatar
tandrus73
Exclamation fires but won't start
Hello, I have a '92 E-150 with a 302/5.0 that won't start. it will turn over at a normal rate for about 20-30 secs will fire at first then it smells like it floods out and then acts like the starter draws too much power. the battery is good i just replaced the starter. ANY HELP PLEASE!!!
Old Nov 26, 2004 | 12:36 PM
Crash687's Avatar
Crash687
you may need to take it to a mechanic and have him plug it into a scanner.
Old Nov 26, 2004 | 12:55 PM
old dad's Avatar
old dad
old dad
crash687 may be right. i like to take my volt ohm meter and tinker with a manual and a few beers. i found that the beers keep me from panicking and the manual has enough info to steer me down the path. in an older car i had the same problems. once it took the charger on start to get it going and the other time i had to replace the crank sensor. good luck
Old Nov 26, 2004 | 06:35 PM
markmc59's Avatar
markmc59
fires but wont start
You really not providing much info, sounds like you may have a few diffrent problems, is there any service codes logged?... does it drag down the starter with spark plugs removed?, do you have enough fuel pressure? possible injector pouring fuel into a cylinder?
Old Nov 26, 2004 | 09:20 PM
tandrus73's Avatar
tandrus73
with the plugs out it turns over fine..as far as the fuel pressure, i removed the fuel pressure regulator and turned the key on and gas came out from there but not much pressure behind it and i haven't bought a code reader yet so im unsure if there are any codes
Old Nov 26, 2004 | 10:22 PM
pfogle's Avatar
pfogle
Sounds like the ICM to me. Take it off, it's on the drivers side fender behind the battery, look for a gray/aluminum heat sink. Have it tested repeatedly, it may not fail the first time. It could be a fuel issue as well, but with the symptoms sounds more like ignition.
