Can't get my 239 started.
Old Jan 8, 2005 | 01:32 PM
286merc's Avatar
286merc
Close enough
Old Jan 9, 2005 | 09:38 AM
Janet40's Avatar
Janet40
Originally Posted by NJ239Y
I have my idle mixture screws turned out 1-1/2 turns, which from what I remember is the basic starting point when you rebuild the carburator. Is that correct?
For an engine that hasn't ran yet, about a tad less than two full turns out. But once you get an engine actually running and warmed up with choke open, forget specs period. It's done like this, turn them out until your engine runs its fastest, then turn inward until it runs just a little bit slower, also try screwing them completely out and make sure your needle end tips are clean, and put them back in, but did you ever set your rockers yet?? Because 60 PSI is too low, it should be at least 90 dry, and with a teaspoon of light oil about 110 at least for that engine....Janet
Sieveboy65
Mar 5, 2012 11:18 AM
Myfreeford
Nov 29, 2011 03:57 PM
resmith1
Jul 19, 2006 09:31 AM
Carbon88
Aug 20, 2004 09:55 PM
1987tc
1983 - 2012 Ranger & B-Series
Dec 7, 2002 11:45 PM
