99 psd 4x4 stuck
Old Nov 26, 2004 | 03:36 AM
nemek's Avatar
nemek
Exclamation 99 psd 4x4 stuck
whats up
i have searched the forums for advice, but this is my first post. Well i live off a unmaintained dirt road and it just recently snowed about a foot. Anyway i turned on my 4x4 low range (manual hubs, with the dial on the dash). And i left it over night. Well the problem now is that it is stuck in four wheel drive. i unlocked the hubs and swithed off the dial but it lights still stay lit and i am still in 4x4. help please
Old Nov 26, 2004 | 05:54 AM
blackf3504dr's Avatar
blackf3504dr
Maybe ice or snow is not letting the vacume motor operate ? Try warming it up with a hair dryer or heat gun NOT a tourch !!
Old Nov 26, 2004 | 08:32 AM
petes4x4's Avatar
petes4x4
if your hubs are unlocked it shouldn't matter the front axle might be turning but the hubs are unlocked and no power is transmitted to the wheels.
Old Nov 26, 2004 | 08:56 AM
Frobozz's Avatar
Frobozz
Yeah, but low range is going to make for a slow trip down the road!!
To get out of 4x4 Lo (and this applies equally well to manual shifted transfer cases, but sometimes brute force will allow you to overcome these restrictions): put the transmission in neutral; put your foot on the brake; turn the switch to 2wd; wait up to 10 seconds. It should come out. If not, try putting it back in gear and moving a few feet and then putting back in neutral trying again.
Neutral (*not* park or drive-but-with-brake-on!) is critical to release the tension between the engine and the transfer case. Having your foot on the brake is safe to keep from rolling while in neutral, but I believe the ESOF system actually enforces is electrically (if it doesn't see the brake, it won't shift out of 4-lo).
Let us know if this worked...
Duncan
Old Nov 26, 2004 | 08:57 AM
petes4x4's Avatar
petes4x4
sorry didn't see "low range"
Old Nov 26, 2004 | 06:56 PM
nemek's Avatar
nemek
Talking thanks
thanks for everybodys help. i took your advise and backed up the a little forward. then i shifted to neutral and turned off the 4x4 and it worked i appriciate everyones help. you will be hearing for me soon
Old Nov 26, 2004 | 10:24 PM
rjwood5's Avatar
rjwood5
Glad it worked out for you. I have found that leaving a 4x4 in 4 wheel drive overnight in cold weather can cause it to want to stay in 4 wheel mode. The best solution is to drive it enough to warm things up a little then try to shift back to 2 wheel drive.
Old Nov 27, 2004 | 10:24 AM
dougger222's Avatar
dougger222
Had this same problem in a 99 F150 with the four low. At 35,500 miles the truch got stuck in four low due mainly to several inches of ice under it. A trip to the dealer and a new four wheel drive motor ($700ish) covered under warranty and a big thaw it was back to normal.
Old Nov 27, 2004 | 05:47 PM
blackf3504dr
Yeah that does bring back memories , I had a '74 Bronco with front and back plows and every once in a while it wouldn't want to come out of four wheel drive......I'd unlock the hubs and lift the rear of the Bronco off the ground with the back blade , put it in reverse to unbind everything . Funny how it can do something like that .
Old Nov 28, 2004 | 11:07 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
My 93 ranger had the ESOF 4 wheel and liked to get stuck in low range quite a bit. Rocking it back and forth slowly was the only way to get it out of low. Dealer even came out to my job site (mud hole) and showed me how to do it.
Old Nov 28, 2004 | 05:56 PM
bryanh04's Avatar
bryanh04
check the fuses. on dads chevy blazer a fuse blew and he was stuck in 4lo for a while
Old Nov 28, 2004 | 08:46 PM
Kwikkordead's Avatar
Kwikkordead
Leave it to Chevy to make a mission critical function fail on a fuse blowing!
Old Nov 28, 2004 | 08:51 PM
barebackjake's Avatar
barebackjake
hey kwik well thats a feat that you can get a chevy in 4wd and work to begin with
