Bronco II Ford Bronco II
Catalytic Converters
Old Nov 26, 2004 | 01:31 AM
kylebronco2's Avatar
kylebronco2
I drive a 1986 4WD 2.9L fuel injected Bronco 2....It has 2 catalytic converters in a row and i am planning on takin them out and having a straight pipe...however ive heard that this could lead to problems regarding backfiring and and misfiring etc.....any info regarding this would be greatly appreciated
Old Nov 26, 2004 | 03:05 AM
turborich's Avatar
turborich
i took my convertors off for a while, it didnt cause any backfires or missfires, however i did seem to loose some low end power belive it or not. it may help boost hp on a beefed up v-8 or a turbo car, but on the 2.9 it didnt. i have since replaced mine with new ones. what about emissions? it wont pass the visual inspection with a straight pipe.
Old Nov 26, 2004 | 08:15 PM
RomerB2's Avatar
RomerB2
I gutted out my cats, and I lost some of the low-end power, but I also gained some of the higher-RPM power. I haven't had any backfires or missfires at all though.
Old Nov 26, 2004 | 09:44 PM
Ken00's Avatar
Ken00
Don't gut them, it causes more back pressure unless you put pipes in them. Overall, you will see no gains if you have good cats.
Old Nov 29, 2004 | 01:15 AM
kylebronco2
Thanks For the feedback...ill post later how things turn out
