Bronco II Ford Bronco II
Hard Getting In Gears
Old Nov 21, 2004 | 07:00 AM
GORDYSBRONCO's Avatar
GORDYSBRONCO
Just Got This Truck, Troulbe Is The Cluch Feels Fine - But You Have To Force It, Into Gear (all Of Them And Rev) It Don't Grind Or Anything, Just Hard To Get It Into The Gear You Want, Its My 17 Yr Olds Truck And He Is Just Learning To Drive A Stick So This Just Makes It Harder
Old Nov 21, 2004 | 12:43 PM
plilikoi's Avatar
plilikoi
The gear lever goes straight into the top of the tranny so there's no linkage that could be sticking.
Change the tranny oil, making sure you use the correct oil for the type of tranny (Mazda or Mitsubishi).
The Mitsu tranny has an inspection plate on the bottom secured by 12 bolts and takes 4.8 pints SAE 80W oil.
The Mazda tranny has no sub-inspection plate and takes 5.6 pints of Dexron II or equivalent.
Old Nov 29, 2004 | 05:33 AM
GORDYSBRONCO
Unhappy
yep it was low on fluid turns out it has a bad leak gasket where the frt half and back half bolt togather never seen a leak from there before ( had 84 and 87 standards)never leaked, but we just got this b2 it don't look like fun thats for sure like to think i can keep adding till spring then pull the trans and do the cluch at the same time, have to see how long before we need to add more fluid again
BBpwer
Aug 6, 2014 11:24 PM
IDIDieselJohn
Feb 6, 2014 10:14 AM
marks500
43
Jan 23, 2011 09:13 PM
dzzavid
Jan 19, 2007 02:35 PM
x12secondjourney
Modular V10 (6.8l)
Jun 12, 2004 07:23 PM
