1978 - 1996 Big Bronco
Bronco pulls when braking?
Old Nov 25, 2004 | 08:18 PM
kameronth's Avatar
kameronth
Just when I thought my Bronco was done breaking something new comes up. When I brake my truck pulls to the left hard. I was doing 60 and hit the brakes and it almost threw me off the road. The wierd thing is that it does not always do it, just when it feels like it, maybe 50% of the time. Any ideas of what it could be? Thanks! btw, 88 5.0
Old Nov 25, 2004 | 08:33 PM
JBronco's Avatar
JBronco
One of your calipers is bad. Sounds like the passenger side, since it pulls to the left. It is advisable to replace them in pairs anyway. A very easy job to do, the hardest thing is removing the wheel...
Replace your calipers and your trouble should be gone, unless there is a RABS valve problem.
Old Nov 25, 2004 | 10:28 PM
WhëëlMå1's Avatar
WhëëlMå1
Yup, a caliper is sticking. JBronco has told you everything I would.
Old Nov 26, 2004 | 12:32 AM
kameronth's Avatar
kameronth
Well thanks, hopefully tommorow I can get around to fixing them. I will let you know how it went.
Old Nov 26, 2004 | 07:53 AM
bronco_94's Avatar
bronco_94
Red face
i just replaced both front rotors and pads, we had the first snow of the season this morning and my front brakes lock right up. she is a 94 e.b. and it has a abs light it use to stay on all of the time but now it dosent. why are they locking up so easy?
Old Nov 26, 2004 | 09:41 AM
WhëëlMå1's Avatar
WhëëlMå1
Do they lock up all the time, or only under certain conditions? One problem that seems to happen to these broncos are flash rusting of the rotors. It is a known problem. It normally shows upon the first use of the brakes. They will lock up quickly, then work fine.
Old Nov 26, 2004 | 02:46 PM
bronco_94's Avatar
bronco_94
only on wet surfaces, like grass and snow but not when it is raining.
Old Nov 26, 2004 | 03:05 PM
hockeyplurr's Avatar
hockeyplurr
Sounds like a wheel cylinder to me I had this same problem and thats what was to me...
Old Nov 26, 2004 | 03:23 PM
bronco_94's Avatar
bronco_94
where is the wheel cylinder located? its my front brakes that are locking up.
Old Nov 26, 2004 | 04:42 PM
kameronth's Avatar
kameronth
Thanks for the help! Just got the new ones, put them on and problem solved. I thinl I got a bunch of mud in the rubber seals and that is what caused them to mess up. If you look in my gallery I posted a pic of my truck in the mud, fun stuff!
smittys5xs
Nov 26, 2012 02:42 PM
1sscav
Sep 26, 2011 12:13 PM
jeandras
Dec 19, 2002 09:12 PM
meilber
Apr 14, 2002 08:14 PM
duck
Nov 11, 2001 11:24 AM
