Throttle Body Cleaning
Old Nov 25, 2004 | 06:16 PM
fredf15097's Avatar
fredf15097
Talking Throttle Body Cleaning
I searched, but didn't get a clear answer. My dad is having problems with his 97 f150 4.6 V8, 95k miles. When he merges onto the interstate, or get ready to pass someone, the truck feels like it is bogged down. It Doesn't do it when he takes off, but only when he downshifts. The truck has recently been servised with a major Tune Up(wires, plugs, the works) I thought that it may have something to do with his K&N intake, so I cleaned the filter, and didn't help much. I thought that a throttle body cleaning would do some good. Would this help? Any insight on this matter?
Posted some pictures if that helps?
Old Nov 25, 2004 | 06:17 PM
fredf15097's Avatar
fredf15097
Sorry you guys, I didn't mean for the pictures to be so big! Sorry!
Old Nov 25, 2004 | 08:28 PM
LxMan1's Avatar
LxMan1
I would try cleaning the MAF first.
Old Nov 26, 2004 | 06:52 PM
fredf15097's Avatar
fredf15097
How do you do that?
Old Nov 27, 2004 | 12:00 PM
LxMan1's Avatar
LxMan1
Check out the FAQ read first thread in the 97-03 forum. Lots of good info in there
Old Nov 27, 2004 | 02:48 PM
kspilkinton's Avatar
kspilkinton
Also take a look at the fuel filters if they haven't been changed in a while. The injectors are designed to run at a certain pressure (19lbs IIRC), the filters get clogged and you'll feel sluggish.
-Kerry
Old Nov 27, 2004 | 04:31 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I'm having kinda the same problem with mine. https://www.ford-trucks.com/forums/s...d.php?t=309613
Old Nov 27, 2004 | 08:53 PM
fredf15097's Avatar
fredf15097
Where is the MAF located, and how do I clean it?
Old Nov 27, 2004 | 10:41 PM
LxMan1's Avatar
LxMan1
See my reply in the other thread that you posted in.
Old Dec 3, 2004 | 01:03 AM
markmc59's Avatar
markmc59
cleaning maf
I used an artist type camel hair brush and alcohol, no, not jim beam, rubbing alcohol, 90% or better, pull the maf from the snorkel leading up to the throttle body and clean with the brush with alcohol, be careful, fragile filament
Old Dec 3, 2004 | 01:05 AM
markmc59's Avatar
markmc59
maf location
in your pics, the left pic, the maf is in the silver body just behind the filter, next to the red hose, black box screwed into the silver metal box
BACKIEL
New Hampshire Chapter
Mar 15, 2007 09:22 PM
TheSequil
Exhaust Systems
Apr 5, 2004 08:44 AM
Amanda25
New Member Introductions
20
Sep 3, 2003 11:56 PM
Nate_64
Aug 23, 2001 09:19 PM
fordblue_ca
Apr 1, 2001 01:48 PM
