Sponsored by: Innova
amp question
Old Nov 25, 2004 | 06:08 PM
Peach's Avatar
Peach
amp question
I have one 10" pioneer subwoofer behind my seat, right now it is running of my head unit only, because i still dont know what amp i want. I was looking at some MTX amps today..and one that stuck out at me was a 200 watt 2 channel, with 160 watts RMS. Can anyone tell me how much RMS watts i need? the sub is 350 RMS. thanks in advance for any help.
Old Nov 25, 2004 | 07:38 PM
LinearPower's Avatar
LinearPower
If you are buying the amp solely for sub use, buy a mono amp of about 300-400 watts RMS into whatever ohm rating your sub is. There are so many good mono amps available that there is no reason to buy a 2 channel and then bridge it.
Old Nov 25, 2004 | 10:06 PM
maticuno's Avatar
maticuno
It's always best to buy an amp that puts out just a little bit more RMS power than what your sub can handle. That way you don't have to turn the amp up so much that it starts clipping. If you go this route, make sure you don't turn the amp up all the way or you WILL fry your sub.
Old Nov 25, 2004 | 10:52 PM
Peach's Avatar
Peach
What kind of mono amp would you reccomend?
Old Nov 26, 2004 | 12:15 AM
Muffinman's Avatar
Muffinman
Is that 350 watts peek or at 1% THD? If its rated at 350 watts peek get a amp that is rated around 100~150 amps.
I use a Alpine M501 that is rated 350 watts at 14.4 volts into 4 ohms at 1%. It can run a 2 ohm at 550 watts. the speaker I run is a Alpine SWR 1041D which is rated at 300 watts @1% THD and 1000 watts total.
Just don't get anything that can't run your speakers rated working load at 1%THD.
Old Nov 26, 2004 | 09:00 AM
Peach's Avatar
Peach
I'm not sure what THD means..but i know the sub is 750 watts max power and 350 RMS
Old Nov 26, 2004 | 03:41 PM
Peach's Avatar
Peach
Anyone know if Profile amps are good?what about lighting audio?
Old Nov 26, 2004 | 07:07 PM
LinearPower
Profile and Lightning are definitely several steps down from MTX, in terms of quality of parts and construction. However, that's not to say they can't be fine if used and connected properly in the right kind of a system. If it fits your budget and you have enough sense to not abuse it, then go for it. It may serve you well for a long time. But, there are reasons these amps are so attractive cost wise. The same reason a Kia isn't a BMW. What goes in to it.
Old Nov 26, 2004 | 08:07 PM
maticuno's Avatar
maticuno
I'm running a Profile California Series 400W Max mono sub amp. It's driving a 10" sub inside my single cab Ranger. Very loud for what it is.
Old Nov 26, 2004 | 08:21 PM
Muffinman's Avatar
Muffinman
Well I broke down and bought a Alpine CDA-9833 Head Unit so I could upgrade without buying a new unit every year. I wanted to control all my amps from the unit and never need to open them up again. I also wanted the V-Drive too.
The V-Drive did make a big differance right off the bat. I had to buy a KCE-510M for $39.00 to contol up to 8 amps. Now I will never need to open them up again.
Old Nov 27, 2004 | 12:00 AM
Peach's Avatar
Peach
What are your opinions on Refurbished amps, im looking at some MTX refurbs..but should i stay away from the refurbs?
Old Nov 27, 2004 | 01:32 AM
RomerB2's Avatar
RomerB2
Some people say stay away, I say go with it. Most of the time, when you buy a new amp, it isn't tested at all, and refurbs usually are tested. I wouldn't go with MTX tho, I would go with Kicker, or Hifonics.
Old Nov 27, 2004 | 01:35 AM
Muffinman's Avatar
Muffinman
If it comes with a factory warranty for one year, Sure I would get one if the price was right. It would have to be a good brand though.
Old Nov 27, 2004 | 01:44 AM
RomerB2's Avatar
RomerB2
Why do so many people like MTX? Good price or what? I don't care for them at all, idk why but I feel like they're cheap.
Old Nov 27, 2004 | 01:51 AM
Muffinman's Avatar
Muffinman
I don't even look at them anymore. There is just to many good amps for a few dollars more to pick from.
