desperatly need help!- thingys next to selinoid
Old 11-25-2004, 04:50 PM
muscletruck7379's Avatar
muscletruck7379
muscletruck7379 is offline
next the the selinoid on my 87 ranger 4banger are two little round things that are wired in and have two vacuem lines that go to the tree on top of the manifold. i need to know if these lines are broken, can it cause the engine to not start?
thanx
Old 11-25-2004, 05:05 PM
el conquistador's Avatar
el conquistador
el conquistador is offline
i cant picture what "the two little round things" are at the moment but if you have broken vacuum lines then they most definately need to be replaced. that could cause the no start
Old 11-25-2004, 05:29 PM
dr jag's Avatar
dr jag
dr jag is offline
just try plugging off those lines at the tree and see if it starts, one of them is probably a purge solenoid for the evap system and the other maybe for the cruise
dr jag
Old 11-25-2004, 07:30 PM
Bart99GT's Avatar
Bart99GT
Bart99GT is offline
Does it have a smog pump? If so, those are the bypass and air diversion solenoids. The other end of the vaccum lines go to the combination valve on the back of the smog pump.
Bart
Old 11-26-2004, 12:19 AM
muscletruck7379
i dont really think that they go anywhere but to the solenoids, i'll look again though,
