max boost??
Old Nov 26, 2004 | 10:33 AM
motovert2001's Avatar
motovert2001
and the tops of your pistons.I hit 11 -12 psi at 3000up,10psi at 2300-2800 on a pull.at 1500 it will run about six psi.my pyro never goes over 900 unless i'm on a several mile hill with a big load.i don't have black smoke.i get about 14-16 mpg towing of not depending on speed.
Old Nov 26, 2004 | 11:05 AM
RawPower's Avatar
RawPower
Ok thanks. Do you know about how many turns on the wastegate control arm it takes to go up one psi?
Old Nov 26, 2004 | 12:05 PM
why165's Avatar
why165
my banks guage doesn't even read to 17, it stops at 15 . i think i will turn it up to 11 that would be up from the 9 that banks regulated me to from the start, thankyou for the good info
Old Nov 26, 2004 | 02:08 PM
Spectramac's Avatar
Spectramac
ATS and Hypermax both say 12 lb max, but mine has gone to 18 for short periods. The new wastegated kits claim they actually make peak power at 8 psi. They say more will actually slow them down (using power pumping those extra few pounds).
Old Nov 26, 2004 | 02:55 PM
RawPower's Avatar
RawPower
Mines got a wastegate, should I set it up at 8 or 10?
Old Nov 27, 2004 | 07:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
1500 I show 6 PSI
2000 I show 9 PSI
2500 I show 12 PSI
3000 I show 15 PSI
Old Nov 27, 2004 | 10:10 PM
RawPower's Avatar
RawPower
Ok thanks...
Im going to set it at 13-15, maybe do a little expiramenting to see how high I can get the boost at low rpms yet still have under 15 at 3000 rpm...
