85 ranger ignition switch
Old Oct 20, 2001 | 10:12 PM
Ultramagdan's Avatar
Ultramagdan
Old Feb 7, 2002 | 07:05 PM
jamlam1's Avatar
jamlam1
i am trying to change the ignition switch(not the key switch)and it appears to be bradded into place...any info on replacing this...any help appreciated...thanks
Old Feb 7, 2002 | 08:25 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Jamlam, take another look at it. It should be held in place with 2 "tamper-proof" allen screws. You can either drill out the screw centers, or buy a set of tamper-proof allen wrenches. All auto parts stores sell them.
Old Feb 8, 2002 | 03:38 PM
jamlam1's Avatar
jamlam1
[updated:LAST EDITED ON 08-Feb-02 AT 04:46 PM (EST)]thanks for the suggestion,but these are not tamper resistant allen.it looks like a rivet or a bradded head.there is no hole at all
Old Feb 10, 2002 | 01:39 PM
destiny88's Avatar
destiny88
These are not tamper proof. These are what they call break-off bolts. The head of the bolt was on top of what looks like a rivet. The bolt was tightened until the head broke off. This is to make it harder to steal. I have done an ignition switch on my 86. Drill a hole in the center of the bolt and take an easy out and remove the bolts. When I put my switch back in I used two valve cover bolts out of a 2.3 mustang engine. If you want you can try and take a small chisel and drive it into the side of the head. Once you have a good dent take the chisel and try and turn the bolt by using the dent to hold the chisel as you hit it in a counter clockwise direction.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
