defrost problem fixed
Old Nov 25, 2004 | 08:11 AM
78crewcabjohn's Avatar
78crewcabjohn
I fixed my defroster last night. There are two different damper doors in the duct work. The vaccum accuator motor on the door was the problem. It did not have enough power to move damper door. The air always blew from the bottom or the panel locations but not the defroster. A $10 part from Ford. It took longer to remove the bottom center panel under the radio than it did to replace the part. Just in time because its starting to snow here in Ohio.
