Weird... Just went and fired up my truck... Forgot to plug it in last night, didn't realize it was going to be so cold... Anyhow, last time I started it last night the WTS was working, but, I'm not getting it, or my e-brake light this morning.
Mind you it started fine, even the first time before I realized that the light hadn't come on and cranked it as soon as the chime went off....
Anyone run into a no WTS light condition without any other problems?
Well, if the WTS light doesn't come it, it is supposed to mean the PCM isn't on either, so I would guess that a bulb burned out. My truck is 900 miles away from me right now or I would go check.....are the WTS and the e-brake lights next to each other?
under and a little to the left of the WTS light is the "door ajar" light, then right next to that (to the left) is the "brake" light...i had to go look
The E-brake light started working again once the truck warmed up. Not sure about the WTS light, as that was the last time I drove the truck(was taking it in for a safety inspection) And I won't get it back until Monday(long story short, stuff got broke, wrong parts got ordered, should have been done today...)
It sucks when other people have to put their hands on your rig.
How cold did it get ? I've had it where things wouldn't work until they warmed up, then all was normal .
