I found a truck I would like to buy, but need help with the vin decode:
transmission is A its a 4spd with ganny low and Axle is 16, it is a 4x4.
the motor is a 300 6cy.
I now have a 1979 F150 with a 300 6cy, 4spd new process 435, 2 spd transfer case 205 new process and rear gear ratio 3:50, it a ford 9" 10 bolt rear end. How well can I pull things ? What kind of gas milage should I get ?
How do I find out about the front axle ? Dana same gear ratio ?
you should get fair millage. about 13 i'd say. the 3.50 should be the same in both axles. i think the 44 and 9" have the same ratios. the 44 and 60 are off. mine is 4.09 front and 4.10 rear.
-Aaron
If you read some posts in the drivetrain forum you will notice, the front & rear ratios were made like that so one of them is holding back the other a LITTLE.
why did they do this. it doesn't make sense. why did they want tension on the t-case. I think it would have been better to have a 44 and 60 with the 4.10's or 4.09's instead of both. Like the 9 and the 44 3.54 and 3.50. theres a big difference there .04. I gues they used that because thats what was produced but why do they want the tension on it?
-Aaron
