86' cracked manifold
Old Feb 8, 2002 | 02:25 AM
bozo4ford's Avatar
bozo4ford
Hello fellow ford owners!
Anyone out there with 127,000 miles,that has a cracked manifold? I was curios on how,or where you found such a replacement manifold. I went to my Ford dealer,they told me that the production of my manifold ceased sometime in the year 2000! I live in a city where most of these parts have been "picked through". The ford parts guy said that the 86' was identical to the mustang 2300 engine manifolds.
The local parts store has a listing for a Motormite cast iron manifold for $130.00. Could this work? Ford was selling theirs for $400.00 two years ago...WOW! Any suggestions? I can not pass my Smog only test with this problem.
Also,reading these other posts...I guess I am in line for a Timing belt,....but this truck is only worth about $500.00!!!!!!
Thanks for any input for my put put! Thanks, bozo4ford
Old Feb 8, 2002 | 06:04 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Search this web site for parts in your area:
http://www.car-parts.com/
I use this site instead of calling around to junk yards.
Old Feb 8, 2002 | 01:59 PM
bozo4ford's Avatar
bozo4ford
Thanks Ranger Pat!
I'm sure you know how frustrating this can be. All the Salvage yards either don't have them,or if they do,they're cracked. One muffler shop said he could order one through Dorman Model number #674-320, manifold including gasket. Have you ever ordered anything through Action Auto wreckers from N.Y.? They are half the price for a new one....decisions...decisions...I over on the other side..California. Anyway,thanks for the reply!
Old Feb 10, 2002 | 01:46 PM
destiny88's Avatar
destiny88
There are a couple of options. I seen the other day on E Bay a manifold dirt cheap. The other option is take it off and weld it. If you get it welded make sure you get somebody good. Do not braze it. Do not use stainless rod. Do it right, a good cast weld is to take the special chalk aand preheat the manifold to the chalk changes colour, then ( I prefer a rod by a company UTP) weld it. I have numerous cast manifolds welded like this. Tractors and a couple of 2.9 fords.
Old Feb 12, 2002 | 09:26 PM
bozo4ford's Avatar
bozo4ford
Thanks ranger pat and Destiny88 !!!!!
I've tried several car places, one of which were helpful,....www.vikingtruckandauto.com) but it would take 4-5 days,where I found one newly re-manufactured one from a Salvage yard,in the box,(old/new stock)which I think I will use instead of the weld job. I'm sure if it's done right,it should maybe last for another 50,000-100,000 miles,but the major problem I have found by talking to owners of old rangers,that if the cat converter gets plugged,it will overheat the manifold.
Thanks alot! bozo4ford
Old Feb 12, 2002 | 11:21 PM
joes75's Avatar
joes75
