Rear differential humming
Old Nov 24, 2004 | 06:59 PM
restoration man's Avatar
restoration man
I have a 1995 F-150 4x4 with a 8.8 rear end. There is a constant hum from about 10 miles an hour up. I have replaced the outer wheel bearings and seals and the carrier bearings. Can anyone help me with this problem?
Old Nov 24, 2004 | 08:37 PM
ATC_250SX's Avatar
ATC_250SX
hows the pinion, loose? wiggly? did you look at the ring gear, any funny wear?? how many miles, it sounds to me like the gear lash is out of spec. maby from a bad pinion bearing or something
Old Nov 24, 2004 | 09:04 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Follow this link and read the articles on diagnosing noise:
http://www.ring-pinion.com/tech/techind.html
If you can get the truck up off of the ground and run it in gear you can listen with a stethoscope and pinpoint the noise. Parts that make noise usually make heat, you can feel for heat.
Old Nov 25, 2004 | 07:18 AM
MustangGT221's Avatar
MustangGT221
Sounds like the ring and pinion are not set correctly. What you should do is take the cover off, clean all the fluid out, than roll a pattern on the gear teeth with some marking compound, and see where the contact patch is. Once you see where the teeth are actually touching, it will indicate where the teeth need to be moved around for proper alignment. This is not an easy thing to do, it requires a good understanding of what adjustments do what....
Old Nov 25, 2004 | 09:26 AM
ATC_250SX's Avatar
ATC_250SX
start basic, if your pinion nut has backed off, (yes they do it) it will cause your gear lash to be off, so start there, by wiggling the pinion yoke, that will give you a good start then go and check the lash like MustangGT221 said, by this point you may want to have a rearend or tranny shop check it out for you.
Old Nov 27, 2004 | 09:42 AM
Michael Littman's Avatar
Michael Littman
How is the fluid level in the transmission? When the bearings on mine began to get worn I suspected the rear end as well.
buddy316
Dec 10, 2015 09:12 AM
emmagator
Jan 6, 2010 06:10 PM
emmagator
Jan 5, 2010 09:39 PM
Adrianx
Jan 14, 2009 09:53 PM
speedindevil
Jan 19, 2004 01:26 PM
