Cheap suspension kit with little to no lift
My truck ('74 F-100) came with MOOG replacement coils up front, my brother installed them for the guy that used to own it. He told me that they have a higher load rating, brought the truck to level. I havn't had any problems with them since I bought the truck in '91(?).
Suspension bushings are available in kits.
What are you hoping to gain?
OK, lets re-phrase the question: Better for what?
Ford tried to assemble the best all around compromise they could. If your goal is an all around, do everything truck, you have it.
If your intended useage is more hauling than anything else, or more off road than anything else, you move from compromise to sacrifice when it comes to street driving.
I think napa carries the MOOG line. Just about everyone (and thier pet dog) carries poly bushings in kits, I've seen rubber bushings (I think) at LMC truck.
If your taking the fix-whats-broke approach, start with the bushings. If the factory installed your current bushings, I'd say they've had a good life. If your leaf springs have the teflon anti-friction pads, replace the pads. If not, disassemble the spring pack, clean the contact surfaces and spray with Lubriplate.
Just replacing these wear parts may be all the improvement you want.
Good luck, Mike
Good luck, Mike
I don't know, I haven't looked at them- just kidding.
Park the truck on LEVEL ground, stand back 20 to 30 feet and do a walk-around inspection. Compare from side to side; corners same height? Do the springs look pretty much the same as their counterpart?
You'll probably notice a difference from front to back; low in the front is most common. Some people like to replace the front coils to level things out. Mine got replaced a few times because P/O would break either springs or mounts (Rancho), rear leafs are original, interchange with the 3/4 ton 4x4.
Look at the leafs from the side; any cracks, broken leafs, broken fittings?
Same for coils, any cracks or breaks?
When in doubt, take it to a pro. Take it to a dozen pros, get a consensus. It's your blood ,sweat, and tears going into this project.
Good luck, Mike
Good luck, Mike
