View Poll Results: emissions or non-emissions vacuum port
use emissions port
0%
use non-emissions port
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
which vacuum port
Old Nov 24, 2004 | 11:46 AM
munrow's Avatar
munrow
which vacuum port
'86 351W w/Edelbrock 2181 intake, Edelbrock 1406 carb.,no emissions or related hardware, no A/C or related hardware, Hedman Hedders, MSD 6 series ignition, 2 1/2" dual exhaust. (Originally set up for emissions control.)
Anybody know if the distributor vacuum tube is supposed to go to the emission or non=emission side of the Edelbrock 1406 carb. if the engine has no emissions? Only sign of emissions are blocked-off exhaust outlets on back side of heads.
I assume it can be tuned for either?, but don't really want to screw around with it that much if I don't have to.
Thanx for the advice...
Old Nov 24, 2004 | 11:55 AM
TheWiz427's Avatar
TheWiz427
Find a port that has vacum during acceleration and connect it to it.
There was no need for a poll!
Old Nov 25, 2004 | 02:10 AM
munrow's Avatar
munrow
If both ports didn't have vacuum on acceleration I wouldn't be asking about it.
There's no need for a lot of things people do! Especially ones suffering from sporadic bouts of immaturity, such as myself.
Old Nov 25, 2004 | 06:01 AM
jwtaylor's Avatar
jwtaylor
Well from the factory it was set up with timed vacuum (facing carb left port) starting with 6-10 degrees initial.
You may wanna explore full vacuum (facing the carb right port), I have done some reading and since tried it, the engine performs like night and day, in a positive way. I don't plan on changing it back to timed any time soon. later
Old Nov 25, 2004 | 07:43 AM
munrow's Avatar
munrow
Sorry about the poll and the... immaturity.
Thanks for the input, I currently have it on the right-facing port because of the difference in performance. Didn't know if it was pure chance in adjustments or if that was the correct side (kind of figuring things out as I go). Thought it was possible that I had things so screwed up that the wrong side worked better.
