Electronic Temperture Control Problems???
Old Nov 24, 2004 | 09:28 AM
ddwood55's Avatar
ddwood55
My son has a 97 Explorer Limited. Last summer he started having problems with the A/C. It would blow cold for a while then all the sudden it would be blowing warm air. Now that he has had to use the heater a few times he has the same problem with the heat. At times it will work fine then all the sudden it will start blowing cold air. I've searched this forum and got some ideas on what to start looking at. But I'd also like to know if there is a self test you can do on the Electronic Temp Control. I know his 86 Turbocoupe had a self test you could do.
Thanks,
Delos
Old Nov 24, 2004 | 12:48 PM
hank_48's Avatar
hank_48
Got this from an earlier post by Homer Winzlow -
Electronic Automatic Temperature Control Module Self-Test
The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A NGS tester must be used to retrieve these concerns.
The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTC) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when performing the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
If a condition exists but no DTCs appear during the self-test, refer to the Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
To exit self-test and clear all diagnostic trouble codes, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
Always exit the self-test before powering the system down (system turned OFF).
Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Old Nov 24, 2004 | 03:24 PM
ddwood55's Avatar
ddwood55
Thanks, That was what I was looking for. Must not of used correct wording to find it in my search!
Delos
Old Dec 9, 2004 | 10:23 AM
njf207's Avatar
njf207
any idea what this code means on the climate control self test 025
Riceburnerfb1
21
Jun 28, 2016 04:45 PM
Riceburnerfb1
Jun 25, 2016 05:34 PM
DougForce
Jul 20, 2014 11:40 PM
Padlock
Jul 8, 2014 02:22 PM
atruscott
Dec 25, 2013 11:25 PM
