Wider stance
Old Nov 24, 2004 | 07:30 AM
fordxxx's Avatar
fordxxx
Wider stance
When I look at my '72 from behind the width between the tire looks really narrow with the stock wheels. How do I widen it out without screwing up the handling. Can I bolt on wheels with a different off-set. I notice that the F-150s from the 80s and 90s look wider...would set of wheels from one of these?
I have seen other 67-72 around that have a wider meaner looking stance. Ideas?
Thanks
Old Nov 24, 2004 | 08:03 AM
Six Niner's Avatar
Six Niner
hey if i'm not mistaken the rearends on the 67-72 are actually narrower than those on 73-up. different offset wheels should make it look wider though.
Old Nov 24, 2004 | 02:50 PM
rebocardo's Avatar
rebocardo
I would just find a van rear end and swap that in with some welding, going different off-set tires is not really a solution, especially if you rotate your tires.
Old Nov 24, 2004 | 03:02 PM
SRD4X4's Avatar
SRD4X4
rebocardo,I see the signature so I won't dis-agree,but I'm just wondering,Aren't the van rear's wider than pick-ups? .73-79 pick-ups are about 4'' wider than 67-72.Did you mean a van rear from a 72 ?
Old Nov 24, 2004 | 10:29 PM
stevef100s's Avatar
stevef100s
I myself went the wider rear rim and tire route, and the correct offset to even things up from front to back. Kind of the streetrod look. It's all about what each person likes in their own opinion.
Old Nov 26, 2004 | 01:23 AM
71100's Avatar
71100
put some 15x10in wheels w 295/50/15
Old Nov 26, 2004 | 06:48 AM
jowilker's Avatar
jowilker
Brian, The front and rear tracks were the same through 64. Ford introduced the wider front track I-beam in 65 and left it that way until 73. In 73 the rear frame and axle was widened to match the front.
You can use a rear from 73 to 86, by cutting and moving the hangers to the narror stance. The newer rear is about 4" wider and offset tires can be tricky to get on & off. It will work.
John
Old Nov 26, 2004 | 08:14 AM
fordxxx's Avatar
fordxxx
John, as soon as I read your post I ran out and measured the front and rear track width. The rear is about 3 to 4 inches narrower than the front. I never knew this.
I don't like the idea of having different wheels on the front and the back...just doesn't seem right. So I will have to think about if I want go to the trouble of changing the whole rear end.
Thanks at least now I know what the problem is.
Old Nov 26, 2004 | 01:06 PM
rebocardo's Avatar
rebocardo
Yes. When talking 9 inchers, the vans come with wider rear axles, usually 31 splines, and the largest rear drum brakes compared to F-100/F-150. So, they make the best "wider" bolt in upgrade and tend not to be beat to death like a truck (4x4) axle found in the bone yard and have not been taken off-road.
Plus, you can find many vans with SRW Dana 60 rear ends, which is a bonus upgrade even if it came off an ambulance and you have to redo your driveshaft.
Being from Canada, I doubt he will have many 73-79 pickups to choose from and later model vans that are rusted out with low mileage are more likely to be found in a junkyard. imo.
Old Nov 27, 2004 | 05:46 AM
jowilker's Avatar
jowilker
Aint it amazing what ya can learn on FTE
I wish I could start over with what I have learned here. A lot of things on my truck would be different.
John
Old Nov 27, 2004 | 06:57 PM
ranger240's Avatar
ranger240
personally, I think the narrower rear axle will bennifit my project, as I do intend on getting some BIG!!!! meats under there, making some mini tubs and a possible "C" notched frame to get it in the weeds. I am going for the resto-modern look, with all of the modern ammenities. I guess it all depends on your plans as to what you are going to do with your truck.
Old Nov 29, 2004 | 12:03 AM
Nod's Avatar
Nod
drive track
I did not like the look of my 71 F-100 4x4 rear being four and three sisxteenths of an inch narrower track than the front.I bought a set of wheel spacers from Performance tire and wheel and now the truck looks great.
"bowties in the rearview mirror"
Old Dec 30, 2004 | 02:10 AM
custom69's Avatar
custom69
different rims will help but if you put wheel spacers on back you will save your self some money and time but your studs might not be long enough, also if you live in a state where it snows the same track width from bacl to front will benefit you alot
Old Dec 30, 2004 | 09:11 AM
woods's Avatar
woods
Most all vehicles have the rear axle narrower than the front.
It helps the rear track better.
The rear would have a tendancy to push more around corners if it was the same width.
Old Dec 30, 2004 | 08:25 PM
rebocardo's Avatar
rebocardo
re: narrower rear axle
Actually, it helps the front track better, by making the turning radius smaller, so the rear inside tire does not scrub as much ... or something like that The wider the rear axle, the more likely it is to push the front axle straight through a turn instead of tracking after the front axle. Especially on a slick surface.
I know it is a model car site, the information still applies:
http://www.rctek.com/handling/ackerm...principle.html
When trucks (like the newer Rangers) are designed by Ford to dog track, it is usually to favor the right hand turn over the left.
