Hi,
i need some ideas what this could be.
Truck (signature) runs well, start up is no problem, cold and hot, the idle is very good at ~ 600 rpm, but when i give some gas that the rpm is about 1500 and i let fall the the rpm suddenly, the egine begins to bucking cause of a low idle, 200 - 400 rpm and sometimes it dies. Sometimes it comes back and the idle is fine again.
I installed new gas tanks, new fuel filter, new air filter .... could this be something caused from the ignition or the electronic egine control ?
The Fuel pumps run also well ! could it be that 2 gallons in one tank is to little ? for running the 5.8 l
